An 8 cavity mould for a coat hanger using the Cool-One system. The moving half cores are made of Beryllium-copper for superior heat transfer. The Mould dimensions are 900mm x 670mm x 601mm. Use 7zip to unpack.
The uploaded file contains all part and assembly models. Although this is a completely accurate injection mould design I can only allow it to be used for educational/training purposes.
This design is the property of ECA Product And Mould Design CC and may not be reproduced, republished, distributed, transmitted, displayed, broadcast or otherwise exploited in any manner without the express prior written permission of ECA Product And Mould Design CC.
I'm not quite sure what you mean here: "If you have an easy method if you tell me what I can do sevinirim. Too bad I crashed. Please look into flaws". Anyway I will try to upload the other files once I get a chance, I am quite busy at the moment though.
I would be glad. I've seen similar patterns. system, I would like to compare them. your design looks more beautiful than others
can you step file so i can open it in inventor ? good job
