Missing_feed
Ar15 lower receiver
This is a pretty common design for an AR15 lower receiver. The receiver is the part of the firearm that houses the operating parts. The receiver usually contains the bolt carrier group, trigger group, and magazine port. In the USA the lower receiver is the only part that is technically considered the firearm, so check your local laws before making this CAD model into real life!
  • John Evans
    John Evans over 1 year ago
    You are da man. Thanks
  • Steven Kiley
    Steven Kiley about 1 year ago
    This is a pretty hack-jobbed model. Had to fix quite a few broken features, and there were some incredibly necessary steps/features to create the geometry. None the less, I appreciate the effort and you saved me time either way, Thanks!
  • Erik Shafer
    Erik Shafer 5 months ago
    Meh I get the same result running Featureworks on an iges. Still sloppy and most of the features are part of the "imported" feature - can't be edited or removed. Sigh.
