A simple clamp assembly. Also attached 2d working drawing
Nice model, what did you use for the render? I like the effect with the model on top of the part drawing.
Thanks Kevin.....I used realistic raytracing visual mode in Autodesk inventor to achieve the render effect, no special render Just Inventor 2012 realistic visual mode
nice, clean render, good job
