Join our community of over 1,820,000 engineers and 600,000 CAD files
Missing_feed
Craftsman Wrench Sockets
This is a single Solidworks model with a design table that has configurations for the following 14 Craftsman Wrench Sockets. My apologies for the file size. I wanted to label these sockets, and while you can link sketch text to a configuration property, you cannot change text height in design table. Therefore, I created a new sketch and cut feature for each label. This increased the filesize by more than double. Also included is a sldprt version without the label that is significantly smaller.
42060 - Wrench Socket 5/16 in
42061 - Wrench Socket 3/8 in
42062 - Wrench Socket 7/16 in
42063 - Wrench Socket 1/2 in
42064 - Wrench Socket 9/16 in
42065 - Wrench Socket 5/8 in
42067 - Wrench Socket 3/4 in
42070 - Wrench Socket 8 mm
42071 - Wrench Socket 10 mm
42072 - Wrench Socket 12 mm
42073 - Wrench Socket 13 mm
42074 - Wrench Socket 14 mm
42075 - Wrench Socket 15 mm
42077 - Wrench Socket 18 mm
I made a couple of renders using the 10 mm combination wrench from William Heidt (10 mm Combination Wrench).
Unfortunately, these aren't available as a set outside of the 28-piece Standard & Metric Reversible Ratcheting Combination Wrench set (Craftsman model #42122, http://www.shopyourway.com/craftsman-28-pc-standard-metric-rev-ratcheting-comb-wrench-and-wrench-socket-set/241955757). This item, however, appears to no longer be available for purchase outside of a few vendors on Amazon.
Oh well.
If you've got these wrench sockets, and need a model of them, here you go. There's also a zip containing separate STEP files of each configuration.
