This is one of the tools used for milling the bearings cage.
Because I worked in the bearing manufacturing field I though that would be helpful for others to see what tools are used to manufacture,probably the most used engineering components:bearings.
The cutting edges(with the lighter appearance) are made from carbide - compound composed of carbon - which is very strong for cutting the brass made cages.
