This mount was designed for a race car rear suspension. It attaches the upper steel subframe to carbon fiber lower support. The suspension bell cranks are mounted on the top with the coil over springs inside the openings. The part is also holding the engine and differential mounted to the rear.
do you have ANY other models from this car? Playing around with some designs as a hobby and this would really help me out
Your model is dynamic..... Nice WOrk :)
