This is a Pseudo Radial Engine made from three OS 61 engines fitted together.
A gearbox is included to connect the drives and give a 2:1 reduction ratio.
The engines are fitted backwards to maintain the correct rotation direction on the output shaft.
The engine was downloaded from 3D ContentCentral.
__________________________________________________
Please press the 'Like' button (Heart symbol) if you think this model is of good quality, interesting or useful.
veryyyyyyyyyyyyy nice
The problem is the carbs, will that would work perfectly together?
But an excellent job.
