Flat head phillips wood screw - 42 sizes
This was an iPart pulled originally from www.cbliss.com and we broke them apart for our library.
Both Fine and course thread.
If you want the iPart, you can pull it from the cbliss site.
The AutoCAD download is for AutoCAD 3D (2004) format.
  • Randall Lawrence
    Randall Lawrence over 1 year ago
    I really expected a solid model. It came in as a surface. SolidWorks couldn't heal the surfaces and the gaps. So I had to add some solid geometry. I really need a square drive, not a phillips. I couldn't extrude out the square - likewise because is was a surface - which for some reason - interfered with my geometry.
  • Randall Lawrence
    Stan,
    Great work by the way. There was nothing wrong with what you provided. Actually, I think this was a system to system or surface to solids issue. I downloaded and unzipped a whole list of beautifully done step files.
    I am working in SolidWorks 2008. I have used step files before, but I can't recall is I could add or subtract from them. I just needed to extrude a solid square drive hole in the head in place of the phillips. I attempted multiple approaches. My final resolution was to use your model for dimensional guidance and created a fresh SW solid in a new file. A more reasonable man might have simply use the screw as is and ignored the drive feature variance.
    Thanks again.
  • Stan Wile
    Stan Wile 3 months ago
    My guess is its a limitation in your older release of software. I downloaded these again and tried it in Inventor 2012 and they come in as solids. Maybe check your import options. Do you have a heal or stitch option? Sorry I don't have SolidWorks to test right now.
