This is a simple and relatively cheap solution that still look nice and meet the requirements. The main idea is to build the walls of square pillows, stacked on each other. The special made pillows are build of isolation material as foam rubber etc and than coated with clothing. This will reduce sound from outside effectively. Here is something similar:
http://nerdapproved.com/wp-content/uploads/2009/10/brick-wall-pillow.jpg?cb5e28
These are hold in place by a scaffold made of steel L-bars, either mounted with screws or to be welded together. An alternative material could be aluminium.
A sliding glass door should be available from suppliers in desired dimensions. Here is an example:
http://www.andersenwindows.com/servlet/Satellite/AW/AWProduct/awProductDetail/AWProduct/1137170164332/1102951372828?model=200+Series+Perma-Shield+Gliding+Patio+Doors&pc=Window&tab=1-1
An other concept with this solution could be to have all four walls with pillows but the amount of area space would be reduced though but small furniture's could be a solution.
For virtual effects these models where used:
Chair by: Jaydeep.C
table by: Zeljko Fabijanic
Bar chair by: Maragera
Round Table by: Tobias Mattsson
Sliding door:
http://www.3dcontentcentral.com/secure/download-model.aspx?catalogid=171&id=294213
by: Rob Winckel
With kind regards
Josef Snabb
Thanks for letting me know. It took me around 8 hours to complete. I would really like to compete in more challenges. =) Thanks for this competition. The only feedback I have is that it should be a second and third prize, at least a T-shirt or something. This will motivate more competitors and attract more competitors I think. Cheers.
Yes, that's true. Actually I will do it now on Phone Booth Challenge.
Okey, good to hear that. :)
