Krimelte Foam Heater Catia (V5R21)
Our ideas is heating to penosil tube with water because of equal heat distribution.
Penosil Gum is heated from 0 to 20C degree by the adjustable warmer which used to heat water.
*Foam Heater has resistance which requires 24V,
*220V to 24V adapter is mounted,
*Safe for the user,
*Can be clean with chemicals (e.g. acetone,detergent ) ,
*Heater designed from standard electrical parts,
