Tire Changing tool. One Handle, Pivot post. Interchangeable Remover and Install Tool.
To remove tire tip up remover at angle to place under tire bead, then back down to post and rotate off. To install push Tire down past rim, set installer and rotate on.
Some feedback from Generat: Really nice interchangeable parts! The downside is that the rim needs to be properly fixed somehow.
great
