Pneumatic Punch with a 3 stage SMC cylinder operating the Punch. It has a guided SMC cylinder that translates it in and out of punch position on the press tool. The Punch Housing is custom designed for vacuum extraction of punched plug and built in rotation disable device.
  • Terry Stonehocker
    Terry Stonehocker over 1 year ago
    Thanks Anoop, yes this is my true side...I am a mechanical engineer first and a motorcycle nut second.
  • Keegan Leach
    Keegan Leach over 1 year ago
    Can you tell me why noting symmetric or mated together?
  • Terry Stonehocker
    Keegan, not sure about the symmetric problem...I checked the assy and everything is aligned fine.
    As for the mating of the parts, I drew this model in desktop and translated it to solid works and the mates did not transfer. I did not bother to go through the assy again and re-mate it.
