Note*** : My solution is for one pair of wheel. I don't know if it goes along with the ambiguous requirement "Axle solution for one pair of wheels".
I know this is what most people will end up with. I've not inovate in any ways, but I still think it is the best way to do this. It's very straight foward, it has 2 major parts to produce (laser cut and metal folding) and some fasteners. No welding.
*A spacer could be added (blue part on render 4).
*Note that on the renders the shock should be on the other side (the side where the leaf spring is sliding, not the pivot side)
But nonetheless, a really good design of yours and great modelling :)
9 months agowhich part is rolling and which part is staying on the hub assembly? i couldnt get it.
actually i dont what part has to roll what has
9 months agoto stay.
Celmal, the only rolling part is where you can see the bolting circle on the hubs.
Thanks for your comments!
9 months ago
