Here' the step file of my turbine rc model engine. I have opened this up to check or verify that all is working ok. They seem load nicely but one file has an error but seem load ok.
Info:
This is model after the KJ-66 turbine only that it is a little larger in size, combustion chamber is longer and wider in diameter
i was locking for this engine for a while , thanks
good work, thanks
thanks,i will try one!
