Tutorial:How to make a crane hook in pro/E.
Step 1: Sketch required hook section.
Step 2: Create datum points on sketch.
Step 3: Create Swept blend (follow steps)
select the sketch under option references then
Swept Blend step 1: select the datum point 0 as section 1 and sketch the required profile(eg: circle) to outer side of hook sketch and divide circle with 6 points and click to finish sketch.
Swept Blend step 2: Next select the datum point 1 as section 2 and sketch the required profile(eg: rectangle with fillets as per my sketch) to outer side of hook sketch, click to finish sketch.
Swept Blend step 3:select the datum point 2 as section 3 and sketch the required profile(eg: circle) to outer side of hook sketch and divide circle with 6 points and click to finish sketch
Swept blend section view: Now we can see the required hook as per screen shot.
Next click the check box tick and u can see the finish hook profile.
Note: The division of points should start from same side as per my screen shots.
Thank You
