Water pump
  • Luiis Bernall
    Luiis Bernall 11 months ago
    Thanks citravis!
  • Thaynan Pereira de Faria
    Thaynan Pereira de Faria 11 months ago
    can you explain where did the engine can be sited?
  • Luiis Bernall
    Hi Thaynan, well, in this model i did´t fit the engine because the proposal was only visual, but if you are a solidworks user you can model the engine and fitting on this piece, just make a "shell" operation for main body and you can put the engine in, i hope this be the answer you was looking for. regards!
