Pattern using table is very easy. I have uploaded a tutorial please follow it
Step 1
For this tutorial I made a ring with OD 100 mm and ID 60mm. and created a hole of dia 10 on PCD 80 at 15 degree as shown in the image
Step 2
I will show you how to pattern this hole on same PCD but at different angles
select the hole and click pattern and opt for table pattern as shown in the imageStep 3
Select the driving dimension as shown in the image.
Step 4
Now you need to edit the table , follow the image
Step 5
you need to enter the angle and give serial no (1,2,3...) as shown in the image
Step 6
Finally your pattern will look like this, You can take any feature and any driving dimesion to pattern of your choice. Enjoy
Hello sir, Can i use the same pattern table to some other part model. If so let me know pl. prabhu1974@gmail.com
