I had not found pneumatic standard components in Autodesk Inventor for routed systems flexible housing and coupling components. The cilinders and the rest of the components are available for download from the different webpage companies.
You're right Esteban. There is nothing related to pneumatic systems in the Tube&Pipe Styles... I'm sure it's on the wish list for future versions!!!
What I do is I download the components and publish them to a library I created. I also had to create the hoses and a new Style for the Tube&Pipe runs.
Check out my Semi-Automatic separator Press
it might help a little...
William... You can create your own library :) include it in a vault too! I could try to do a tutorial but I don't promise nothing.
Hi Jonathan - I have just read this question and I didn't know you can created your own library for IV.... I take it you can access this library through your content centre? or is it just a directory you create on your own computer?
That is good to know I shall look in to it first before you take the time to do a tutorial Esteban but it is very much appreciated for the offer :)))))
