Catia V5 to Cura gigantic mesh (.STL)
Hi,
I have some models in catia which I wish to 3D print. In order to export to cura I would save my files in .stl format. The problem is at the import from Cura, the object seems to be gigantic.
Is there some sort of ratio I need to take in consideration? Or some sort of option from Catia,Cura?
Do note, I have designed the piece which is no bigger than a 9V battery.
Thanks for the help
