can any one know how to create sprocket
Download models directly from traceparts.com and edit as you require.
I would make the hub, then next feature woud be one tooth. Pattern the tooth about the axis.
AutoCAD Autodesk Inventor CATIA NX Pro/Engineer Wildfire PTC Creo Elements SolidWorks Solid Edge Other
