Edit a mate reference in Assembly Document
By Mahan on 31 Jul 13:38 1 answer 172 views 0 comments
I want to edit some mate references in the Assembly Document but when i change them, it doesn't work. What should I do to see the changed parameters effects?
Thanks sincerely
1 answer
  • Aled J Taylor
    Aled J Taylor 10 months ago
    I'm not sure exactly what the problem is but you could try the following:
    Delete the mate and put it in again as you want it.
    If you have many 'fixed' components in the assembly, 'float' them.
    'Ctrl' Q to rebuild.
Add your answer to: "Edit a mate reference in Assembly Document"
