extrude option in solid edge assembly is disabled ,how to make it work? dhivagar 3 Apr, 2014 11:49 AM I'm designing a chassy(assembly frame) on which mounts should be placed . Making use of sketch I drew the profile but extrude option is in working. could someone help me out off this. 1 Answer jacksonbenom93 Answered on 24 Mar, 2016 04:30 AM Assembly is to assemble models and not to create models. You have to either create a model and then go to assembly or you have to create models within an assembly(using Home => create part in place).
