can anyone help with this problem...trying to use the trim/extend to face feature and it does not seem to be working. i have a pipe with a rod running through it and i want to trim the rod where it intersects with the pipe.
howard if you upload an image
then someone will be able to help you
a lot quicked with your problem my friend
I agree, frame generator is rather hard to provide answers for without a picture so a picture will go a long way.
@william...This is an assembly file of the items. And i think the easiest thing to do would be to draw all the parts regularly, but i wanted to take advantage of the built in library of frame generator.
Door_Jamb_Handle_001.iam, 89.5 KB
Download
Hi howard you have only uploaded the IAM so I will not be able to see all the IPT's within the IAM :P
@william...here is a .idw file.
Door_Jamb_Handle_001.idw, 230 KB
Download
