From SketchUp to STL Plugin?
By Ricky Montero on 30 May 06:30 4 answers 651 views 1 comment
I just saw the 3d View option...
and I want to use it
how can i export STL or 3d view from sketchup?
  • Anoop krishna
    Anoop krishna 10 months ago
    there is a plugin from sycode for exporting a sketch up file to STL file,but not for free you have ti purchase it.
  • didier godefroy
    didier godefroy 10 months ago
    if you want to pay for plugins, sycode has many plugins for a large variety of CAD platforms.
    http://www.sycode.com/
    and there is also simlab:
    http://www.simlab-soft.com/3d-plugins/SimLab-Plugin-for-SketchUp.aspx
    they also have a plugin to import/export in many formats, including STL, but they're not free either.
    there are such plugins available for free, and they can coexist in the same SU install, by showing up in different menus.
    I use the STL import plugin from Jim Foltz, which shows up in the file>import menu and works great.
    there is also an STL import export plugin that shows up in the plugins menu, it can be found on sketchucation http://www.sketchucation.com/ and googling for its file name leads you there as well: su2stl.rbs
    and there is one other that exports to either DXF or STL and shows up in the tools menu, but I forgot where it came from.
Add your answer to: "From SketchUp to STL Plugin?"
