HOW add forming tool to design library
By Hamidreza Rastan on 30 Jul 09:56 3 answers 466 views 3 comments
my solidworks 2011 does not have forming tools in design library,how can i bring forming tools to my design library???
  • Mehdi Brahmand
    Mehdi Brahmand 10 months ago
    سلام.
    حمید جان مشکلت دقیقا کجاست؟؟
    برای منم که 2011 بود نداشت. گویا هرچی ورژن 2011 تو ایران هست این مشکلو داره وقتی هم این فایل رو تو جای اصلیش ایجاد کردم باز جواب نداد. بهترین راه حل رو تو عوض کردن ورژن دیدم. دلیلش هم اینه که اکثر نرم افزارا تو ایران خوب کرک نشدن و کامل نیستن. مخصوصا نرم افزارای تخصصی و مهندسی
  • Rohit Mitra
    Rohit Mitra 10 months ago
    This video will take you through saving your own custom form tools http://www.youtube.com/watch?v=ob5L-fIGI9s&feature=player_embedded
    By default you should have form tools available with the design library. Make sure you have the right file location. Go to tools>options>system options> file locations and set the design library location to C:\ProgramData\SolidWorks\SolidWorks 2011\design library
    or simply add
    C:\ProgramData\SolidWorks\SolidWorks 2011\design library\form tools
    as a new design library
    -Rohit
    100's of SolidWorks Tutorials >>>>> Solidwize
  • Brian Long
    Brian Long 10 months ago
    Create the form tool that you need, the initial sketch will be used as a placement sketch. Click the forming tool on the sheet metal toolbar, select stopping face, select faces to remove and click ok. I took this straight out of the help files. Try doing some research before asking the question.
Add your answer to: "HOW add forming tool to design library"
