Previously when I added tutorials for the challenge there was a space for the text and a space for the picture. Now there is only add file space. Where is the text space?
Branko I did't understand your problem Step 1 you have to use this button, I think you click on '' add files to answer'' by mistake Step 2 you can write here
you can write here
Thank you, now I understand.
I can only add three steps
AutoCAD Autodesk Inventor CATIA NX Pro/Engineer Wildfire PTC Creo Elements SolidWorks Solid Edge Other
