How can I convert AutoCAD 2010 dwg files to STEP/IGES
Someone has asked me if I can upload one of my AutoCAD dwg files ( UK 3PIN DOMESTIC PLUG ) IN STEP/IGES file format but I'm not sure how to do this.
File export (select file type, sat, iges,......)
select objects.....
File will be created.
sat-file added.
Regards
hey could you please convert my .dwg file to .igs (or whatever file that would help me to open this file in HyperMesh) ?
well, i only used the option "save as" and choose "other formats"; in the extension options it appears the 2010, 2007, and 2004 .DXF format, so here it is your file; peace!
hi. first click on file option on bar then select the EXPORT item in open panel then again select the format to change or save your work in IGS or STP.
In the command line in AutoCad, you can type stepout this will export the file in step format. typing igesout will export it in iges format.
Hi all.
Please could someone convert the following Autocad 2016 DWG file to STEP or IGES (parametric), so it can be edited by SolidWorks ?
My email address is psubiaco@creasol.it
Thanks a lot!!!
http://docs.creasol.it/case_ST.dwg
if you want to change the file format , must click ,on top of screen on left hand , A icon then choose EXPORT afterward choose one of the formats that showing on new TAB then choose format and save
Hi Folks
I have no answer but am looking for such.
Since I can not afford to buy AutoCAD or any other CAD, I am trying to use FreeCAD which uses the IGS/STP or STEP format.
I tried several converters with "This is not a true 32bit software" error flashing back to me.
I run windows 5 ( 32 bit - there is a 64 bit mode but sucks). I also have Linux Mint 17.3 and have FreeCAD on it as well.
I am trying VariCAD but having issues. Am in contact with them for help.
Any suggestions, folks?
Being on disability prevents me from splurging of $50 plus software!
OH! I do have an 8 bit CAD 3D from Expert Software I bought back in 1998. It works but not comparable with today's memory hogging software.
Any help?
Thank you in advance
Ed - KB8QEU
kb8qeu (at)gmail(dot)com
