How can i get local control in spline curve?
By Sudhir Gill on 25 Jan 04:27 1 answer 510 views 0 comments
How can i get local control in spline curve? Whenever i changes one control point the whole curve change.
1 answer
  • Tomica Vukovic
    Tomica Vukovic over 1 year ago
    Control point of 2D spline has two parameters for controling of properties.
    One is marked as arrow - you can add a numerical value for it - it is represented as an angle.
    Second is marked with diamond, it is curvature value and you can dimension it and changing values.
    1. Step 1
      Start position with constrained spline. all data had dimensions.
      Medium
    2. Step 2
      Changing value for curvature produce following shape.
      Medium
    3. Step 3
      Changing angle produce following shape of spline
      Medium
    4. Step 4
      Changing a dimensions of control point of spline produce following shape
      Medium
Add your answer to: "How can i get local control in spline curve?"
