If I am creating a pattern and I need to remove some of the elements from the pattern, how do I do that?
Hello Branko. It is simple. When you are in the Pattern menu there is an option in the bottom called "Instances to skip". Click there and you will see small points showed on every element, then just click on points of the elements that you will remove. Regards. /Josef
