Missing_feed
how create wind turbine blade in catia
By jamil bin ahmad on 15 Jun 12:24 2 answers 1138 views 0 comments
what are step need to consider
  • Er.akshay sharma
    Er.akshay sharma 11 months ago
    it can be used by using part design and wire frame design in catia.step by step
    step1-draw external profile in part design
    step2-revolve it
    step3-draw the required profile on surface i.e on the plane.
    step4-select any perpendicular plane and draw external profile of blade.
    now enter in wirframe and surface design
    use sweep command to extrude i.e sweep-along pulling direction. select law
    select liniear and give required angle
    and extrude in given direction.
    tis is required blades.
    soon i will upload a video tutorial about this
  • Samuel George McCammond
    Samuel George McCammond 9 months ago
    Hi I have just uploaded a VAWT produces 1kW electricity using a NACA section twisted as shown. Made in composites with aluminium frame. Wind tunnel tests showed that it is slicing the wind and not being rotated. Modifications are on the way. There are only certain NACA sections suitable for wind turbines, so you have to do you home work. I have NACA software and luckily the profile required was there so I had a basis to start with.
Add your answer to: "how create wind turbine blade in catia"
