Missing_feed
How do I convert a surface to solid?
By Anne Håland on 03 Jun 01:23 2 answers 550 views 0 comments
Hi.
I'm doing my master thesis and I need some help to convert a surface to a solid object. I need it to be a solid object cause of the 3D printer I'm going to use. I tryed several of methods that I found on the internett, but I'm not able to make it work. Can anybody help me?
  • Bozidar Sevic
    Bozidar Sevic 12 months ago
    Hi,
    Conversion is a pretty sensitive area in general, but try with the software called Mesh To Solid 3.0
    I think it may take a while to convert it depending on your mesh file, but it's worth trying.
    Boz
  • Kush Desai
    Kush Desai 5 months ago
    First Do Make the surfaces U want in Surface tab ( in Tradional orderd or ST enviroment) .. Then go to HOME tab then in :"Solids" Module U fine one option called "ADD " Below the Thinwall Command ....just use Dropdown manu of " ADD " command n you fine an Option called " THICKEN "
    to get solids, n Follow the Instructions n U Done
    One PDF also Attached this shows all surface operations in SolidEdge
    SolidEdge_Surface_Modeling.pdf, 2.51 MB
    Download
Add your answer to: "How do I convert a surface to solid?"
