How does a *.cgr format differs from other similar (step and iges) formats in Catia V5?
By Abhijeet on 15 Jan 18:26 3 answers 1279 views 1 comment
  • Schrotter
    Schrotter over 1 year ago
    cgr-files only present the outer surface of a part/assembly. This surface is tessellated (consist only of triangles). This format is only for representation (DMU).
  • KFZ-Schule
    KFZ-Schule over 1 year ago
    If you get an IGS, STEP file, you can´t see the history, but you can work with the surfaces or volumes (for example edge fillet or hole)
    If you get an CGR, you can´t see the history and you can´t work with it.
    greetings
Add your answer to: "How does a *.cgr format differs from other similar (step and iges) formats in Catia V5?"
