Found this topic and thought that GrabCAD engineers might have an answer:
"I am very new to this whole concept of having ilogic based rules to drive your part design. I have even gotten as far as creating a ipart and having ilogic rules be able to suppress, unsuppress, change values and dimensions using ilogic rules. I now want to be able to use ilogic rules to drive some of the various(yet similiar) assemblies that I create all the time.
For instance, If I have just a flat plate as the base component with a shaft welded to it that varies in length for my assemblies. Since the shaft varies in length, I went ahead and created iparts for all the lengths of the shafts. I can manually change which shaft I want represented in the assembly, but I would like to to know how do I get Ilogic to place the different shafts based on user parameters?
I've looked into component place iparts, but can't seem to get the code to work. The list of iparts tree within the model doesn't pop up in the model tab in the ilogic rule, only the base component. Any help or guidance on this subject would be very much appreciated."
Autodesk Inventor 2012 Tutorials - iLogic - Overview
http://www.youtube.com/watch?v=fltp0IXq64UAutodesk Inventor 2012 Tutorials - iLogic - Parameters
http://www.youtube.com/watch?v=mUG4CQX_ImwAutodesk Inventor 2012 Tutorials - iLogic - Parameter Filters
http://www.youtube.com/watch?v=jZEwmYOPl6YAutodesk Inventor 2012 Tutorials - iLogic - Feature Suppression
http://www.youtube.com/watch?v=pvMKpEA7yNwAutodesk Inventor 2012 Tutorials - iLogic - Dimensions
http://www.youtube.com/watch?v=LxSpm1IfH8AiLogic Vessel Tutorial
http://www.camansol.com/tutorials/iLogic/vessels/transcripts/VesselIntro.pdf
Very interesting topic, I will be investigating this in the next couple of weeks/months, will give you feedback if I stumble across something of use.
