how I can add liquid to a tank with KeyShot (detailed tutorial please)
good friends I will model a steam engine but has a deposit where some fuel supplies and want learn how I can make this liquid with KeyShot
You are able to do calculation through mathematics about its Volume and flow speed of Steam.
If you are Designing a Steam engine than you need only perfect Calculation and there is no way to Insert the Liquid through Key-shot, because Key-shot will always provide the Texture's and Realistic Effect to Things/parts Which is Already Designed in Complete Assembly or Part Details.
So If You really Wanna Doing Experiment with Steam or Liquid Effect than Kindly use the Software and fill it up like here in this Tutorials said Approx Everything related to Key-shot......."https://grabcad.com/questions/35tutorials-keyshot-tips-step-by-step"
