Just select the material and the click apply material command.... select the material you want to apply and then click apply then ok....
good luck
Cheers SHYAM
Hi,
Unlike V5, there are no predefined materials by default in Catia V6.
We need to define prior to using/applying them.
But if you are importing any Catia V5 files having materials applied, it will save them while importing.
Next time you clik on apply material command, it will show them.
