how to assign the material to learn it weight?
created tube 1 m long
on the Internet I found how much should I weigh pipe, and as NX to do it?
To Assign a material to any object in NX open the required file and select the tools drop down menu from the top tool bar, in the list select > materials >assign materials. A menu opens to select solids then select the required material and choose apply. You should then be able to retrieve the weight using the properties function. Hope this helps and is clear enough. Regards, Taurus
