how to calculate the clamping force?
By dassault on 11 Jun 13:04 2 answers 1118 views 2 comments
please tell me clamping force at this clip Toggle Clamp
  • Aled J Taylor
    Aled J Taylor about 1 year ago
    The clamping force will be many times the force that is applied to the handle. It depends on how the clamp is adjusted. But I'm sure you know this already. This is how I would calculate the force:
    1. Set the clamp in its over-centre position.
    2. Reset the clam in an under-centre position with the same angels.
    3. Resolve the forces on the handle to work out the force that the handle applies to the clamping lever.
    4. Reset the clamp to its over-centre position.
    5. Apply the force calculated in step 3 to the clamping lever.
    6. Resolve the forces in the clamping lever.
    I hope this helps.
  • Aled J Taylor
    Clamps are available here:
    http://www.wdsltd.co.uk/
    The clamping force on these is specified.
    CAD files can also be downloaded.
Add your answer to: "how to calculate the clamping force?"
