How to change material properties for good in solid edge?
By Duško Kuzman on 14 Jun 13:01 2 answers 1684 views 0 comments
The procedure is as follows:
My Computer - Local Disk (C) - Program files - Solid Edge ST4 - Custom -
Material Table Editor - Read Me file - Bin Office 2007 (or 2010) - Material Table Editor - follow three "easy" steps (1. export Excel file with material properties (if you get message "Could not start Excel" - don't worry, just try couple of more times ), 2.modify material properties, 3. import Excel file).
It's never working, no matter how many times i try.
In the end I always get the message:
The material table file is not available for write access.
  • tushar
    tushar 11 months ago
    go to properties and select first option material properties change material as required
  • Duško Kuzman
    Duško Kuzman 11 months ago
    I find a way:
    Defining material properties in solid edge st4:
    1.Open model (part) in ISO Part
    2. Inspect menu - Physical Properties - mvProperties icon - Physical Properties dialog box - below the Density window click on the Change - new dialog box Solid Edge Material Table is open - select or modify the properties of certain material - click on Apply Model - click on Update and then Close
Add your answer to: "How to change material properties for good in solid edge?"
