How to connect multiple lines in Solid Edge?
By Ivan Stojicic on 14 Jan 21:18 1 answer 878 views 2 comments
If you have bunch of lines...100 or more...is there some way to connect them all?
1 answer
  • Eby
    Eby 12 months ago
    You can use circular pattern command to make them joining at a point.
Add your answer to: "How to connect multiple lines in Solid Edge?"
