How to convert a stl./step/mesh into a 3dm. file or a nurbs model to be able to edite in Rhino
By David Sevilla on 30 Nov 00:52 1 answer 2020 views 0 comments
I would like to know how to convert a stl/step/mesh file into a 3dm. file so that I can edit it in Rhino 4.0. I also wonder why most organic models are in a mesh form. are they easier to join or something. I know in Rhino when you model something all your edges have to line up or you get a bunch of naked edges wich means your model is not water tight and to my understanding unable to print it or prototype. Thank you. sorry for long description.
1 answer
  • latheesh
    latheesh about 1 year ago
    try to open this step format in NX, Solid works or any other cad software and patch your surfaces first, then use the same file for Rhino...
Add your answer to: "How to convert a stl./step/mesh into a 3dm. file or a nurbs model to be able to edite in Rhino"
