How to convert AutoCAD 2011 .dwg files to AutoCAD 2008?
I would like to convert AutoCAD 2011 .dwg files to 2008. Can anybody please be so kind and help? Thank you.
Agata, I assumed this was a file that was an email attachment, in which case it can't be opened and needs to be downsaved to an earlier version before the user can access the file.
The simplest method is that when are going to save the file choose the option "save as". A window appear on your screen. Then select the version of the file in which you want to save it. e.g, 2008.dwg.
That's all.
u can use Export file to IGS or AUTO cad 08 or open your file in AUTO cad MEP and export this to older version of cad software.
its easy...
1.PRESS RIGHT 'CLICK' @ MODEL TAB
2.GO TO OPTIONS
3.CLICK 'OPEN & SAVE'
4.FIND 'SAVE AS'
5.CLICK THE 'BOX'
6.THEN FIND THE LOWEST VERSION OF AUTOCAD 2000/LT2000 DRAWING (*.dwg)
7.PRESS 'OK'
8.THEN TRY TO SAVE YOUR LATEST DRAWING FILE..
THATS IT...DRAWING FILE IS READY TO BE OPENED @ AUTOCAD LOWER VERSIONS
sorry I'm late to this one, however for future reference Autodesk's "TrueView" software is now a free download and will convert the most recent DWG's to a couple different prior years' versions.
