How to convert enclosed surface to solid in CATIA?
By Sudhir Gill on 23 Aug 05:58 3 answers 1972 views 1 comment
I had created several surfaces such that they are having enclosed region. I want to create solid from this region. How to convert it?
check the file attached
Part1.CATPart, 642 KB
Download
  • AMOD GIJARE
    AMOD GIJARE 9 months ago
    Hi sudhir
    what you can do is use the following commands shell, close surface and thick surface and your surface will be created into a solid part
  • gurudath
    gurudath 7 months ago
    is this what you are trying to achieve?
    Added images
    Square
    Part1.CATPart, 169 KB
    Download
  • hamid moaiery
    hamid moaiery 9 months ago
    dear Sudhir Gill
    you could import to catia with iges or step format and then thicked them to solid.
Add your answer to: "How to convert enclosed surface to solid in CATIA?"
