How to cut extrude along a path in SolidWorks?
By Hardi Meybaum on 06 Oct 04:48 2 answers 1841 views 1 comment
Helping fellow engineer
"I have a thin tube that will fit into a larger solid piece. But the catch is that the tube needs to be bent at a radius through the solid. I am trying to do a cut extrude through the solid to accomodate this tube."
  • Kir Ari
    Kir Ari over 1 year ago
    Do the sweep cut, pick the same sketch as you did for the pipe as extrude scetch, and pick the path (you can pick the edge of the solid if I understood you correctly).
Add your answer to: "How to cut extrude along a path in SolidWorks?"
