How to design a sprocket teeth when you know roller diameter and pitch of the chain?
By cnc-akura on 06 Mar 09:06 1 answer 968 views 1 comment
how to design a sprocket teeth when you know roller diametre and pitch of the chain.I have a 400mm diametre wheel and i will use 40mm chain rollers.The chain will be a open loop so i want to know how to design the profile for the wheel teeth.
1 answer
  • SHYAM
    SHYAM 8 months ago
    first draw the reference line for the required dimensions of the sprocket teeth and then just connect with profile command... use corner and chamfer command for finishing....... good luck.........
    Cheers SHYAM
Add your answer to: "How to design a sprocket teeth when you know roller diameter and pitch of the chain?"
