Missing_feed
How to draw glass in a door?
By howard.slr on 03 Jul 01:30 7 answers 398 views 0 comments
What is the best way to draw glass panels in a door using inventor. and when drawn does it show up in the drawing file?
  • Alan Baird
    Alan Baird 11 months ago
    Hi Howard
    Just change the transparency of the material, I use Alibre Design Software and if I am designing something which has glass in it I use a light blue colour and adjust the material transparency so that you can see through the material. Im sure there is a similar function in Inventor.
    Kind Regards
    Alan BAird
  • Alan Baird
    Hi Howard
    Try this one
    Click on the view boundary.
    Hit s on the keyboard.
    Project Geometry the part boundary to hatch, then right mouse button Done.
    Add additional sketch lines to define boundary if needed.
    You can now add the hatch while in sketch mode from the Hatch tool.
    Click return to exit sketch.
    Kind Regards
    Alan
  • William
    William 11 months ago
    As Alan said just change the material and yes it will show up in the drawing file as it is just an IPT only with the material changed.
    :P
  • Tomas
    Tomas 11 months ago
    Hi Howard,
    It depends on how you started working on Your project. Autodesk Inventor has more than one way, how to do it... So, if project You started in 'ipt' file (example - door), then You must create another 'ipt' file (example - glass). Assign a material.
    These two files have to combine in 'iam' file. Use "Place" key to combine files. There you will have two different files. ;)
    The other way, then You started in 'iam' file. Just use "Create" key for different parts. Also assign the materials.
    In other cases, you can use "Component Priority" ---> RMC ---> Properties and select material from list. :)
    Finally, if you are using other software for rendering, can not bother with the materials.:)
    Best Regards
    Tomas
  • howard.slr
    howard.slr 11 months ago
    these are all great answers, but i was thinking more about after creating the .iam (assembly) file and then moving to create the .ide (drawing) file. how do i get the glass to show up in an elevation view with a glass hatch pattern.
  • Tomas
    Tomas 11 months ago
    Hi Howard.sir,
    Maybe just try to use colors in IDW file: on view ---> rmc--->edit view--->shaded.
    Maybe I will not understand the problem :)
    Best Regards
    Tomas
Add your answer to: "How to draw glass in a door?"
