How to export autocad drawing in pdf i real scale?
Hi I don't know to export autocad drawing in pdf i real scale every time when I export form acad to pdf for A3 paper size I get my drawing just on half size of A3 paper size.
P.S. See attach file.
i hope it answer your question
Answered with a tutorial: https://grabcad.com/tutorials/how-to-export-autocad-drawing-in-pdf-i-real-scale
you have to print your work using a virtual printer like DWG to PDF or Adobe PDF and select " plot to file"
www.cutepdf.com - it's free. install and cutepdf will be in your printer options drop down. just print as you normally would but with cutepdf as your selected printer. it will prompt for a "save as" to save the pdf.
Hello! I use Universal Document Converter (http://www.print-driver.com/how-to/convert-autocad-dwg-to-pdf). With this program you can convert drawing dwg to PDF in real scale. Good luck!
Aslamulak'am about my to answer about your questions:
1st i make the Drawing project inside layout and click right for layout and change paper size .
2nd use tools bar view-port after make single window for Ur project in layout and change scale as u like .
finally printing ur project as scale i hope u understand me ...
step 1 : press ctrl p
step 2: select window
step 3: specify Area
step 4: define printer name like ( AutoCAD pdf hight quality print)
step 5: select preview
step 6: ok
step7: save a pdf file
