Missing_feed
How to extrude a self-intersecting or curves drawing into 3d?
By azher99 on 12 Jul 20:07 2 answers 984 views 1 comment
How to convert Map type drawing into 3d. Extrude option does not work in autocad 2010 software and shows the error message that can't sweep or extrude self-intersecting curves.
  • vicky
    vicky 10 months ago
    It could be extrude in the form of surface.
    When it is in form of segments.The curve shouldn't be a polyline type.
    If the desired curve is in form of polyline,then software give error.so first explode it make its surface then convert it surface to solid from modify tools..
    Thanks
    Vikas
  • SLMO
    SLMO 10 months ago
    you just need to use the command boundary to convert your drawing to a region then you can apply extrude command from solid panel and you will have what you want
    for any more details just leave me a message
Add your answer to: "How to extrude a self-intersecting or curves drawing into 3d?"
