A group in the MIT media lab called "Mediated Matter" is trying to '3D print' houses using similar techniques to normal 3D printers. Is there an easy way to generate tool paths?
Maybe that you can try simulate all model with G-codes whis is used in part production on CNC mill machines.
When you have a maked part simulate it on addins for machine production to getout a G code sequences.
