how to get 3d solid model in catia drafting(not in wire frame)
I draw an part model when i import to an drafting workbench and double click on work space it convert in to wire frame model .my task is like pro-e i want to place solid model in drafting sheet it is possible in catia or not
Hi Sathish, It's Very Easy. First Insert the View Normally in drawing sheet, Then Right click view-----> Properties--->go to View tab----->Drag the mouse to down----> Generation mode-----> Here you will see Default Exact view, Please change it to Raster------>click Options(Near to Raster right side tab)-----> Generation mode options window will open ----->and now here change to Shading with Edges----->Then click ok
Regards
Ezhumalai
