How to loft the edge?
By Hardi Meybaum on 28 Sep 12:56 4 answers 959 views 10 comments
How to loft the top edge of the surfaced shape up to the circle sketch?
Tutorial would be great.
You can find project information here - tPackage
Tryng to help Rye Croven.
tPackage1.SLDPRT.zip, 241 KB
Download
  • w.wolf
    w.wolf over 1 year ago
    Here you go ...
    1. Step 1
      Open the file, make a new 3D sketch, 2D sketch works too in this case ...
      Medium
    2. Step 2
      Select the edges you want to loft then click on Convert Entities ...
      Medium
    3. Step 3
      Your model should look like this; now close the sketch ...
      Medium
    4. Step 4
      Click on Lofted Surface ...
      Medium
    5. Step 5
      Select the two sketches either from the model window or feature tree and click the green arrow ...
      Medium
    6. Step 6
      And you model is finished, it should look similar to this ...
      Medium
  • w.wolf
    Wow, I don't believe I missed it ... You don't need sketches for lofting edges, open your file ... click on Lofted Surface, right click the Profiles box and choose SelectionManager ... choose all the edges then the green arrow, click on the circle sketch and you're done ...
  • Cemal Uslu
    Cemal Uslu over 1 year ago
    There is no direct way to do it i see. Just redraw the shape of the top again and Loft the surfaces.
    lofted surfacetPackage1.SLDPRT, 428 KB
    Download
    1. Step 1
      Select Top Plane Which is the top of the shape too. Open a scetch.
      Medium
    2. Step 2
      Draw a sketch just like the shape of the top. Be sure there are 20 edges not 10.
      Medium
    3. Step 3
      You can draw 2 of them and circle pattern them 10 times.
      Medium
    4. Step 4
      Select Lofted Surface and fill in other options.
      Medium
    5. Step 5
      Everything looks just fine.
      Medium
  • Rye Crowen
    Rye Crowen over 1 year ago
    Yes, thanks everyone for answering this. I'll post the model and render of it soon. Cheers.
Add your answer to: "How to loft the edge?"
